Global Security & Compliance Statements
We do our best to provide continuous security updates for our IoT products. The security updates generally include the latest security patches, security vulnerability fixes, and other security improvements. We will maintain the security updates for at least 2 years from the launch day of certain device models.
- Australia
- United Kingdom
- EU_Data_Act
SOC Documents
Our smart home devices sold in Australia comply with the Cyber Security (Security Standards for Smart Devices) Rules 2025, which came into effect on 4 March 2025.
The above Statement of Compliance is prepared in accordance with Australian legislation and applies to products sold within Australia. We will review and update these documents as regulations evolve.
SOC Documents
Our smart home devices sold in the United Kingdom comply with relevant UK regulations.
The above Statement of Compliance is prepared in accordance with UK legislation and applies to products sold within the United Kingdom.
| Product Name | Model | Status | Date Issued | Document |
| Doorbell Camera Hub G410 | CH-C09E, CH-C09D,CH-C11E,CH-C11D | Active | 2025-05-13 | View PDF |
| Camera G100 | CH-C08E、CH-C08D | Active | 2025-05-12 | View PDF |
| Camera Y100 | VB-S01D,MCCGQ11LM,MS-S02 | Active | 2025-03-03 | View PDF |
| Camera Hub G5 Pro (Wi-Fi) | CH-C07E、CH-C07D | Active | 2025-05-12 | View PDF |
| Camera Hub G5 Pro (POE) | CH-C03E、CH-C03D | Active | 2024-12-12 | View PDF |
| Floor Heating Thermostat W500 | UT-A01E, UT-A01D | Active | 2025-03-24 | View PDF |
| Climate Sensor W100 | TH-S04E, TH-S04D | Active | 2024-12-26 | View PDF |
| Wall Outlet H2 EU | WP-P01D | Active | 2025-05-12 | View PDF |
| Vibration Sensor T1 | VB-S01D | Active | 2024-09-14 | View PDF |
| Hub M100 | HM-G02E, HM-G02D | Active | 2024-2-27 | View PDF |
| Hub M1S Gen2 | HM1S-G02 | Active | 2024-04-09 | View PDF |
| Hub M2 | HM2-G01 | Active | 2024-04-09 | View PDF |
| Hub E1 | HE1-G01 | EOL | 2024-04-09 | View PDF |
| Hub M3 | HM-G01D,HM-G01E | Active | 2024-04-09 | View PDF |
| Camera E1 | CH-C01E | Active | 2024-04-09 | View PDF |
| Camera Hub G2H Pro | CH-C01 | Active | 2024-04-09 | View PDF |
| Camera Hub G3 | CH-H03 | Active | 2024-04-09 | View PDF |
| Smart Lock U200 | EL-D02D, EL-D02E / KP-X01D | Active | 2024-06-12 | View PDF |
| Smart Lock U200 Lite (Kit) | EL-D02E,EL-D03E,EL-D03D | Active | 2025-05-13 | View PDF |
| Smart Video Doorbell G4 | SVD-C01, SVD-C02 | EOL | 2024-04-09 | View PDF |
| Presence Sensor FP2 | PS-S02D,PS-S02E | Active | 2024-04-09 | View PDF |
| Presence Sensor FP1E | PS-S03E,PS-S03D | Active | 2024-06-12 | View PDF |
| Temperature and Humidity Sensor T1 | TH-S02D | Active | 2024-04-09 | View PDF |
| Smoke Detector | SD-S01E、SD-S01D | Active | 2024-10-23 | View PDF |
| Door and Window Sensor T1 | DW-S03D | Active | 2024-04-09 | View PDF |
| Motion Sensor P1 | MS-S02 | Active | 2024-04-09 | View PDF |
| Water Leak Sensor T1 | WL-S02D | Active | 2024-04-09 | View PDF |
| Panel Hub S1 Plus | MP-K03D | Active | 2024-11-13 | View PDF |
| Touchscreen Dial V1 | DS-K01D | Active | 2024-11-07 | View PDF |
| Display Switch V1 EU | WS-K02D | Active | 2024-01-07 | View PDF |
| Dimmer Switch H2 EU | KD-R01E, KD-R01D | Active | 2024-11-07 | View PDF |
| Light Switch H2 EU | WS-K08E, WS-K08D,WS-K07E,WS-K07D | Active | 2024-07-17 | View PDF |
| Wireless Mini Switch T1 | WB-R02D | Active | 2024-04-09 | View PDF |
| Wireless Mini Switch | WXKG11LM | Active | 2024-04-09 | View PDF |
| Valve Controller T1 | VC-X01E, VC-X01D | Active | 2024-07-22 | View PDF |
| Cube T1 Pro | CTP-R01 | Active | 2024-04-09 | View PDF |
| LED Bulb T2 | LB-L03D、LB-L03E | Active | 2024-12-11 | View PDF |
| Wireless Remote Switch H1 (Double Rocker) | WRS-R02 | Active | 2024-04-09 | View PDF |
| Smart Wall Switch H1 (No Neutral) | WS-EUK01,WS-EUK02 | Active | 2024-04-09 | View PDF |
| Smart Wall Switch H1 (With Neutral) | WS-EUK03,WS-EUK04 | Active | 2024-04-09 | View PDF |
| Roller Shade Driver E1 | RSD-M01 | Active | 2024-04-09 | View PDF |
| Curtain Driver E1 | CM-M01 | Active | 2024-04-09 | View PDF |
| LED Strip T1 | LEDS-K01, LEDS-K02,RLS-K01D, RLS-K02D | Active | 2024-04-09 | View PDF |
| Door and Window Sensor P2 | DW-S02D, DW-S02E | Active | 2024-04-09 | View PDF |
| Dual Relay Module T2 | DCM-K01 | Active | 2024-04-09 | View PDF |
| Ceiling Light T1M | CL-L02D | Active | 2024-04-09 | View PDF |
| Smart Radiator Thermostat E1 | SRTS-A01 | EOL | 2024-04-09 | View PDF |
| Motion and Light Sensor P2 | ML-S03D, ML-S03E | Active | 2024-04-09 | View PDF |
| Door and Window Sensor | MCCGQ11LM | Active | 2024-04-09 | View PDF |
| Motion Sensor | RTCGQ11LM | Active | 2024-04-09 | View PDF |
| Water Leak Sensor | SJCGQ11LM | Active | 2024-04-09 | View PDF |
| Vibration Sensor | DJT11LM | Active | 2024-04-09 | View PDF |
| Smart Pet Feeder C1 | PETC1-M01 | Active | 2024-04-09 | View PDF |
| Single Switch Module T1 (With Neutral) | SSM-U01 | Active | 2024-04-09 | View PDF |
| Single Switch Module T1 (No Neutral) | SSM-U02 | Active | 2024-04-09 | View PDF |
| Cube | MFKZQ01LM | EOL | 2024-04-09 | View PDF |
| TVOC Air Quality Monitor | AAQS-S01 | EOL | 2024-04-09 | View PDF |
| Smart Roller Shade Controller | SRSC-M01 | EOL | 2024-04-09 | View PDF |
| Roller Shade Controller T1S | CD-M03D | EOL | 2024-09-14 | View PDF |
EU Data Act
U Data Act Regulation took effect on 9/12/2025, Sellers of connected devices in our European stores must disclose how device-generated data is collected, who has access to it, and how data is handled.
